Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
740вопросов Показать все
Black screen illuminated
Hi all,
after a small crash into the floor, my MB shows a black screen with the backlight working. Everything sounds normal (fan, disk unit, hd, front light). Also I've tried resetting the SMC and PRAM.
It seems to be a connector unplugged from the motherboard but any suggestions please (graphics card crashed)?
Thanks in advance
Mario
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
First check RAM
- shared video RAM means if the RAM is unseated you could have this behavior.
If that doesn't fix it you're going to have to open it up and check the video cable connectors to the logic board...
Good Luck,
N.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
or to the LCD panel socket.
из
Hi,
I finally tried by checking each connector in the logic board and it worked.
Thanks you all.
из
Добавьте свой ответ
Mario будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,635
