Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210вопросов Показать все
Force Touch sensor? Still working after a screen replacement.
I changed the screen to my A1554 Apple Watch. When taking the shattered screen off, I didn't realize there was some kind of a sensor so I tore it off. I replaced the screen with a new one and assembled the watch since I didn't have the a new sensor. Now, however, force touch is still working just fine. What's the purpose of that adhesive ring? Do I need to get one?
Apple Watch Force Touch Sensor Replacement
Это хороший вопрос?
Оценка 2
1 Комментарий
I just recently repaired a series 4 Apple Watch screen shattered so badly it didn’t work. I replaced the touch sensor and screen and it boots up but forced touch will not work. Any suggestions? I am at a loss at what to do. I have tried everything forced reset, new screen and touch sensor but still the same result. What am I missing? I have fixed several of these without a hitch.
из
Добавить комментарий
1 ответ
Выбранное решение
The adhesive ring in the Apple Watches, is there for cushion on the display with the 3D Touch sensor. That, and the other adhesive ring around the outer most part of the display is there for water resistance. But it is safe to say that if you replace the screen, your watch won't likely be water resistant anymore..
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Okay, so it affects more to a water resistance. I still don't understand how it's tied to force touch or why it has a connector. The only problem the watch has atm is that the force touch is a bit sensitive (but I think that 'cause there's nothing between the screen and the body other than 3 drops of glue).
If this is the case, I think I'm gonna glue the screen to the body then and finish the job.
из
Добавьте свой ответ
Samu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 1,881
