Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
43вопросов Показать все
isnt their any guides to repair samsung j5 components?
Hi
Can you provide repair guides for Samsung J5?
Это хороший вопрос?
Оценка 2
1 Комментарий
Thanks jamie
I saw this already, but like the Iphone collection they have complete repair guides on most of their components.. isn't their similar guides for samsungs?. or is it that easy to repair multiple component guides are not necessary?.
из
Добавить комментарий
2 Ответов
Выбранное решение
@mystique28 you'll have to first identify which version your phone is. Something like J500F/J700FN (Global Single-SIM); J500F/DS (Global Dual-SIM); J500G/DS (Malaysia, Indonesia, Singapore, Thailand); J500Y (Australia, New Zealand); J500M (LATAM); J500M/DS (Brazil); J500H/DS (Philippines, Russia, Ukraine) will help. when you say you want to repair "Logic Board, Lightning Controller, Display Assembly" you are most likely referring to replacing those. Of course you can always dig a bit deeper for something like this
Maybe all you need are directions like this
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
very helpful old turkey, however depending on the model for instance my phone is a j500fn, will any of the shots above relate to this model, or is it similar for most samsung models?, are their specific step by step disassemble guides like that of the iphones?
из
Tracey Homeward not unless you make these when you work on your phone. Remember that those guides have been created, iDevices mostly by ifixit staff, by users just like you and I. If you have a J5 and want to work on it become a pathfinder for others and create the guides for it. https://www.ifixit.com/Guide/new is a good start.
Yes, those images will be identical to your model. Most of the differences between models will be found on the circuit boards itself.
из
Samsung Galaxy J
Оценка 1
3 Комментариев:
Thanks jamie
из
Which components are you looking to repair?
The guides are only there if users submit them
из
Logic Board, Lightning Controller, Display Assembly?
из
Добавьте свой ответ
Tracey Homeward будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 2,057
