I got salt water in my iPhone 7
I got salt water in my iPhone 7 while on vacation, now the screen is black. I toke it to Apple and they won’t fix because of water. Is it still repairable?
Это хороший вопрос?
Это хороший вопрос?
the faster you get it to a repair shop - the better. salt water is very very (edit: bad) for smart devices (electronics). the motherboard need to be cleaned and tested with new parts.. your chances are 60%. the salt water causes terrible corrosion. hurry to the local repair shop. good luck
Был ли этот ответ полезен?
Just thought I'd emphasize that it would be very very BAD :>). You forgot the most important word.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,067
1 Комментарий
so i had mine submerged for 30 minutes, it worked fine for 7 hours, and went black. what started happening it would start powering on, then going black. after about a few days it worked for about 15 minutes, then started trying to power itself on, then failing. the current situation is it will work for 5 minutes for every hour I let it sit, and it will shorten the 5 minutes to about a minute when charging. WTF is going on?
из evan
