Intalled new 2TB SSD / Computer will not Boot
I have a early 2008 24" Imac w/ 3.06 Intel Processor
I took it upoun myself to replace the HD with a SSD
I successfully(?) installed the SSD and then using my orig intall disc installed OSX 10.5.4
I then installed some updates
I then rebooted using the install disc and used Time MAchine to bring it back to where I was at
Time Machine took 5 Hours to restore
When I try to boot
No Chime
I first get a window that says "Your Computer Restarted Due to a problem"
it then attempts to boot again and I get a scary screen White Text in Black Boxes with lots of Tech jargon
Wont Reboot from install disc
I tried to reset PRAM and SMC no change
Please Help
Thank you
Это хороший вопрос?
What is the make and model of the SSD & how much RAM do you have in your system?
I recommend you run Mac OS-X El Capitan (10.11.6) with a SSD as this is the first release which supports TRIM.
из Dan
