I cant take out the screws on the back
i was trying to fix my 2ds screen when it works but when i took the battery out i found out the screws were impossible take out
Это хороший вопрос?
Это хороший вопрос?
It should be a standard phillips screwdriver. if the screws are not turning, they may be stripped, or you may be using a driver that is too large.
Был ли этот ответ полезен?
yep,they are stripped :/ I was using a 000 Philips screwdriver
if you absolutely need to get them out, it will damage the frame, but you can use a cutting disc attachment on a dremmel to cut a slot into each of them, and use a slot driver to remove them.
thanks.that fixed it!
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 19
За всё время: 1,566
