The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428вопросов Показать все
x box 360 drive is not workin right
when i put a game in to my x box 360 it say that to play this disk put in to a xbox 360 and thats what i got it in to and befor i hit play on the main screen it say play dvd not game
Это хороший вопрос?
Оценка -1
4 Комментариев
Did you change your DVD drive or did anything happen to your xBox?
из
See this question and answers and compare it with your problem. Can you put any 360 disk in to any x box 360
из
ya i had tred to put a diffrent one is cause the first one was not opening right buti got it openin right for now it will open and close right long as i got a disk in if there is no disk in then i got to open it all up and do it that way lol
из
Time for a new drive. If you check online or the previously pointed out question, it is possible just not as a straight switch. Good Luck.
из
Добавить комментарий
3 Ответов
Выбранное решение
It seems like you aren't using the original drive. Xbox 360 drives are "Married" to the console that they originaly came with, and replacing the whole drive will leave you unable to play Xbox 360 game disks. In order to fix this, you need to either fix the original drive using parts from a drive of the same model, or "re-marry" the drives, which is much more complicated. Either way, you need the original drive.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
+ that is my thought as well.
из
+ nice answer
из
The drive laser may be getting weak. Luckily you can disassemble the unit and adjust the strength. You need to be careful, as the tolerable values vary based on what type of drive you have. What XBox 360 do you have and what kind of drive is installed?
Оценка 1
I had the same problem, not reading games but reading music and dvds.
I found a good fix here How to reflash? DVD
I swapped my old circuit board and all is working perfectly.
Оценка 0
Добавьте свой ответ
white dog будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,446
