keeps rebooting ,optimizing app 135
Это хороший вопрос?
Это хороший вопрос?
Hi,
It may be that a downloaded app is causing the problem.
Try starting the tablet in safe mode to check that it starts up OK without rebooting.
If it does then a downloaded app is the problem. The trick is to find out which one.
If you have just recently installed or updated some downloaded apps and then the problem started try uninstalling them first, one by one. Check between each uninstall if the problem has gone by trying to start the tablet in the normal way and see if the problem has gone. If it has then the last app uninstalled was the problem
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 765
