iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
873вопросов Показать все
iPhone 8 not "showing"a charge after the replacement of LCD?
The LCD was replaced. Now the phone is actually charging but no showing the charge. Everything is working. It shows 1% but it actually is charged. Now, it does power on and off on its own? Left it unplugged for two days. It was charged when I came back to check on the process but still showing 1%. Any thoughts?
Это хороший вопрос?
Оценка 1
Добавить комментарий
5 Ответов
was the battery disconnected during the repair and reconnected properly post repair?
Был ли этот ответ полезен?
Оценка 0
Same here.. seems to be related to iPhone 8 & IOS 11.3..,
Michelle what iOS are you using? 11.3 perhaps?
Оценка 0
If your battery is connected correctly as it should be then its related to IOS 11.3 software issues
Оценка 0
Would not be the first problem iphone 8 has with replacement screens on ios 11.3, so could be the ios problem
Оценка 0
Hello, i have this problem too... i change lcd for some OEM lcd and not work touch, now i make update 11.3.1 and touch work... but battery is still 0% and not showing the charging bold... when i connect to charger come first few seconds +/- 1100mA, after strarting OS come down on 200-380mA.... i inspect the board and like 2mm from battery connector missing one small part looks like capacitor etc.... i think this is the ptoblem.... can you tell me some good man what is the part? :)
Оценка 0
Добавьте свой ответ
7michele будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 13
За всё время: 231
