My ipod is locked and I forgot the password
I need help unlocking my ipod touch
Это хороший вопрос?
Это хороший вопрос?
If you connect it to the same computer it is "paired" to for syncs, you can force the pass code off:
You will, of course lose any content which has not synced back to itunes from the iPod...
See also Apple's tech note on this.
Был ли этот ответ полезен?
David Iwanicki's fix also works if your Ipod is stuck in a loop it is step 4 that saved my ipod 32 gig
now i got one more to fix
Works 100%, thanks
thanks alot great
Thank you so much, I goggle on how to unlock iPod touch this was best answer by far, I looked like a pro to my son and became the hero :) thank you again.
it is not dislaing the passkey part it says that i connect to itune
You may get the solution from here: https://discussions.apple.com/thread/490...
try putting wrong password first then hold the lower left button for 5 seconds, then press 3 and hold the lower left button for 2 seconds and repeat... and afterwords when it says wrong password press cancel a message will come up and it will tell you your password is — — — —. (ONLY WORKS FOR IPOD 3G,4g AND IPHONE 4 NO IPOD C OR Cs OR IPHONE 5,5s,6 or 6s
what button??
Restore/ renew from iTunes
It’s not rocket science
Except iTunes is a nightmare to navigate 98% of the time
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 56
За всё время: 147,861
1 Комментарий
Sankaraperugu
из Abhinay Perugu
