Hi,
As you know, water, electricity and electronics are not a good mix.
The water causes corrosion and provides circuit paths for the electricity, which were not in the operating design of the calculator.
First (as you have already done) remove the battery as this will prevent more damage from occurring.
Then the calculator needs to be opened and all affected parts cleaned using Isopropyl Alcohol 90%+ (available at most pharmacies) to clear away any corrosion and water. Do not use "rubbing alcohol" if you can avoid it, as it is usually <70% IPA, can contain scents and is not as effective. If you have to use it, check the label to verify the amount of IPA.
Be gentle when handling the pcb and also do not "brush" away any components from the board when cleaning. Here is a link that in general describes what to do.
Electronics Water Damage
Once you have cleaned it (and allowed the alcohol to dry (evaporate), re-assemble the calculator and check if it operates OK.
Here is a link to the ifixit Texas Instruments TI-Nspire CX guide. I realize that you have a different model, but this may be close enough to be of some help in dis-assembling yours as they appear very similar in design.
Hopefully this is of some help.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
