The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
111вопросов Показать все
Can I replace my screen with an s8 screen?
Hey, I got my phone 2 weeks ago and already managed to smash the screen and break the digitizer. I was wondering if I can purchase an S8 screen and digitizer and replace on my S9? As far as I know, the only difference between the two screens is how bright it can get but that doesn't really matter to me. Will the connections be the same and will it be compatible?
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
No and their not the same physically and technologically.
Был ли этот ответ полезен?
Оценка 1
Комментарии:
I've been using my s8 with a s9 screen for over a year with no issue
из
Seriously? I plan to put s8 screen on my s9 with a broken screen. If what you say is right, it will work.
из
did you finally put the screen? it works?
из
They are actually tje same the only diffnis the frame if you can get the screen off the frame without breaking it it plugs in and works fine I've done it on my own I use the s9 to fix my
Оценка 1
Комментарии:
You did this process yourself ?
из
The answer by Ben is 100% correct they’re technically different and even though they have the same fit and the connector is the same look at the back of a S8 and S9 digitizer and lcd you will notice the difference of certain resistors and or capacitors and certain other things like if you look at the little gold dots near the bottom on the back they’re different. I’ve worked in shops for years and people make this mistake all the time when buying their own parts because the image online will show s8 screen when your trying to get a s9 screen. Even in the shops newer guys after 6 months of constant repairs would sometimes make the mistake but it can cause damage like shorts and even blow out chip/resistors/capacitors I have had it happen to people many of times so if you think you have one of the opposite screens on your phone and it works fine your most likely using the correct screen cause like he said technology is different and there’s subtle difference on the back like look at the placement of the gold dots arranged near the bottom on the back of the screen.
Оценка 0
Комментарии:
I would post a pic but just search S8 lcd replacement vs S9 lcd replacement on google images and you find a pic that shows all The backs of the s series and you will notice the difference if you can get a close loom
из
Добавьте свой ответ
Laimis Minelga будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 18
За последние 30 дней: 94
За всё время: 2,637
