Why won't my computer turn on when plugged in w/battery in or out?
I tried turning my computer on while plugged in, but nothing no power indicator or anything. I removed the battery and tried turning it (still plugged in) and still nothing. I did forget my laptop in the trunk of my car for a couple of days, and I am concerned if it was affected by moisture.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Soooo many reasons could cause this, and the only way to be sure is to run a full diagnostic on it.
you could have a problem with your AC adapter.
you could have a problem with your power button
you could have an issue with the charger port,
you could have an issue with moisture
you could have an issue with board damage
I would try testing for each of those, in that order, to find out what you need to replace.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Daniel V будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 10
За всё время: 49
