battery not charging (green and orange led light flashing)
My Asus F551m has a battery problem, can't recharge anymore, flashes green and orange led when on charger at off state. when on, it shows battery charging but symbol but always at 0% charge, so I concluded that the battery is dead and I decided to buy a compatible battery for replacement. the closer I could get in term of voltage rating is 14.4 v/ 2200mAh/32Wh but the battery to be replaced is rated 11.25v/2850mAh/33Wh.
can I use the 14.4v battery to replace the 11.25v? or is there a way apart of solving this problem of battery not charging (green and orange led light flashing) from replacing the battery?
Это хороший вопрос?
6 Комментариев
charger is in a long time but yet still keeps saying 95%, battery not charging
из Elaine Csiszar
I am facing issue :
# It was not turning on, so i switched on with charger , and it was not turning on, then i went to the different switchboard and it turned on but with red blinking light
# Then to check which part is having problem, i switched it off and then took off battery and switched the charger on, now it's not turning on.
# And after putting battery into it, again on switching on the charger, it's not turning on.
# Pls help.
из Duvii
In my Asus laptop when the power button is pressed red light light up but the laptop do not start
из Chaminda Dias
I have a problem I put my laptop to charge I took it out but the orange light is still on pls help me
из Nasia Stergiou
hey if anyone is having this problem , i have the solution your charger is damaged, same happened with me when i changed the charger it worked.
из Cap Boy
Показать 1 больше комментариев
