Lower memory slot failure.
Hi! Does anybody know the cause of lower memory slot failure (PowerBook g4 A1095)?
One man said it because the north bridge burning and he can replace it with new one .... Any ideas? Thank you!
Это хороший вопрос?
Это хороший вопрос?
I have found on some of these "bad slot machines" that a lesser RAM chip will work when the higher ones will not. I've been able to install 512 k chips in slots that no longer will take the 1 GB chips and its worked fine. Other just won't take anything. It's worth a try if you have the old original chips lying around.
Был ли этот ответ полезен?
I tried 256 Mb DRR from my old hp (unfortunately i haven't got the original chip) and no result
Did you try the HP RAM in both slots to see if it works at all?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 2,075
3 Комментариев
Do you want to know the cause or the work around? The last three letters of your serial number will tell us your exact machine. What RAM chips do you have for this machine?
из mayer
I have to chips Hynix DDR 333 1G. But my powerbook don't recognize the lower memory slot. It's widely known problem. So I have 1G as a result. ;-(
из leon
PC2700U .... from about this mac
из leon
