Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66вопросов Показать все
Showing error 80 while shooting video and now not working
While video shooting showing error 80
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
My buddy is in the same boat with his 70D so Ive been doing some digging trying to find him a solution. It would appear there is a "kind of sort of home remedy" but it requires the camera to at least turn on and be functional at some level. If you can get it to turn on again you can try setting it to record for a set period of time and take continuous snapshots. This may allow the chip that has broken its solder connections to reheat to the point the solder essentially reflows itself.
The only other home remedy I can think of would be to pull the logic board completely out of the frame and apply significant heat directly to the affected chip. You'll need access to a hotair rework station in order to achieve the temps needed to reflow the solder but even this is not going to be a proper fix. Just like with the xbox 360's, this will be a temporary fix at best.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Canon 70D camera is not turn on
из
Добавьте свой ответ
Nate Lin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 750
