Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
Вопросов 20 Показать все
Why aren't my JBL E40BT turning on?
I recently got a pair of JBL E40BT, and today decided to use the BT function. The thing is, it won't work at all. When I plug it in to charge it, it flashes a white light very rapidly, when I take them off the charge and press the BT button, nothing happens. Any idea what I can do?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
The white light occurs only while charging and no device can see the headphones then.
Был ли этот ответ полезен?
Оценка 1
Hi!
In order to use the Bluetooth function, you need to first pair your device to the headphones; the flashing white light indicates that the headphones are ready and waiting to pair with a Bluetooth-enabled device, like your phone or laptop. This is where you should find instructions on how to set up your headphones.
Оценка 0
Did you find the reason ?
I have one of these and not been using for while
When I decided to charge it to start to use again noticed the same behavior
led goes white rapidly flashing while charging, when I remove from the charger, its does nothing
Wonder if is something with the batteries
Оценка 0
Добавьте свой ответ
Lucian Cibotaru будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 2,913
