Samsung 860 SSD causing MacBook Pro 2012 to freeze
Hello,
I am having a problem with my newly installed Samsung 860 Evo SSD. I'm running Yosemite and Windows 7 with bootcamp. When running Yosemite, I'll get the beach ball after a few minutes or so and the OS becomes unresponsive which forces me to do a hard shutdown.
I've already replaced the SATA cable twice in a matter of two weeks. I bought one a $10 one from amazon and then the recommended one from ifixit, I've put electrical tape down under the cable and on both cables, both are causing the same problems. I turned TRIM on and still the problem persists. My bottom RAM slot is definitely finicky, but I loosened the screws on the RAM bay and have been fine for the last couple days so I don't believe it's a RAM issue. Not too sure what to do at this point. Any help would be greatly appreciated!
Sidenote: Oddly enough, my windows 7 partition works flawlessly.
Update (05/30/2018)
I actually sent my 860 EVO in to samsung for "repairs" to see if that would do anything. They just updated the firmware supposedly which did nothing. Nothing left to do but try the crucial MX500.
Это хороший вопрос?
5 Комментариев
You really didn't have a bad SSD you had a bad cable. Alex's your issue was a cable issue either damaged the cable by creasing it or had the original cable which couldn't support the higher I/O flows the SSD can push.
из Dan
six months ago I replaced the HDD in my 2011 macbook pro to a samsung 860 SSD evo 1TD drive. everything was working smoothly until a few days ago when my computer would freeze up with the spinning wheel every minute. When I took out my SSD and put back my original HDD, then the computer works fine again. Do you think I have a faulty SSD ? or do i think i need a new cable?
из entran09
I never found out what caused this issue, new SATA cables didn’t work for me. The only thing that worked was installing a crucial mx500 instead of Samsung 860.
из Alex
@alrodriguez were you able to get a refund for your samsung 860?
из entran09
I don’t believe I tried to get a refund because I ended up using it for a different windows PC - works great when not in a Mac!
из Alex
