Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
49вопросов Показать все
Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)
Hello,
I have a Surface Pro 5 with a cracked screen. I also have a Surface Pro 4 LCD laying around and wanted to know whether I could use the LCD for Surface Pro 4 to replace this screen. The connectors look very similar in pictures, but I can’t open it up to find out as I would prefer to use what I have until I’m ready to spend $230 for a new screen...
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Never mind. Found the answer. Thank you
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
So, what's the answer? I would love to know if they're compatible.
из
No way. The cable hookups are in different locations.
из
Наиболее полезный ответ
The answer is you cannot use a Surface Pro 4 on a Surface Pro 5. The cables for the LCD and N-Trig chip are different.
Оценка 1
Добавьте свой ответ
Quan Hoang будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 1,740
