Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487вопросов Показать все
Samsung S6 Motherboard Bad Need To Retrieve Pics/ Voicerecorder Data
My Samsung Galaxy S6 Has new battery & won't turn on. Was told the motherboard needs replacement, but I need to recover my photos, videos & original music from my voice recorder! I was told it would all be lost if motherboard is replaced. There must be a way to recover this data. Please help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the motherboard is shot, the only option is a data recovery service that will probably remove the memory chip and copy all the data off it. This is something that is possible to do at home, but is EXTREMELY DIFFICULT and requires lots of practice and expensive tools, which most people dont have. This is why you should make backups of data this important. The recovery service will probably cost 100+ dollars. So if this is very important data, do the service. If you can live without it, its gone. There's no easy way. Sorry
Unless you take it to a repair shop and they figure out why the board doesnt work. If they cant fix it, then the solution above is the only one.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
@cam2363 Thanks for your response. It is very helpful.
из
Добавьте свой ответ
Alvin Alexander будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 624
