Windows 10 is a major version of the Windows operating system. It was released in 2015.
21вопросов Показать все
Why I can’t login my Lenovo
I need help my Lenovo have a problem I put in my password and I wait a long time and I got in then the right hand side corner says that cannot login user and says I need to check something but I can’t use the power shutdown switch in there or even general and I tried a few time to restart it and every time when I got in it just says cannot login user and computer will restart in 1 minute
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Are we dealing with a laptop or tablet ? Either way we want to clear the boot memory to get a clean start up so to do this we want to drain all power from the device . . If were on a laptop remove the battery and power cord and once you 've do this then hold the power button down for 60 seconds . Then replace the battery and restart the computer . If your battery is internal then just remove the ram from the laptop and leave it out for a few moments. This will allow for a clean boot If its a tablet then simply disconnect the battery for 5 minutes or so. This will do the same thing . If this brings no joy then lets boot into safe mode and see if were dealing with a computer virus . for this I will need to know the exact make and model of laptop or tablet . Hope this helps if not let us know what(you device) you have and we'll try something else
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
The thing is that my one is laptop and is can’t connect to window service and I can’t do anything I can’t search or use general
из
I can’t connect to windows or anything it won’t let be sign on
из
I have the Lenovo Laptop device
Оценка 0
Добавьте свой ответ
Tony будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 27
За всё время: 7,513
