DSi XL wont turn on
I replaced the upper screen and put everything back together and turned it on and the blue light got bright and then it turned off. When it turned off right away I could tell that both screens flickered. I went back through and made sure I connected everything. The only thing that didnt go back together as well but still is touching is the copper sticky strip that is part of the upper screen and sticks to the metal plate that goes over the microphone doesnt stick as well. I even plugged it in and tried to turn on making sure it wasnt the battery.
Any ideas???
Это хороший вопрос?
2 Комментариев
I have the same problem any help would be handy
из Brad
Hi Mike i have a question. Did you solved your charging problem? Becuase i check both fuse and they are ok.
But i still have the problem.
Thanks for your time.
из memo
