Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218вопросов Показать все
Why does my iPad 4 charge only when the screen is black?
So I have my own personal iPad 3 and a customer just brought in an iPad 4 both with the same problems. They both won't charge unless the screen is off. When you are using the iPad with it plugged in, it says "not charging". But if I watch the percentage with the screen off, I notice it goes up while plugged in. What do I do to fix this? Is it a new battery, or is it a chip?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
This happens when you are using the small 5w iPhone charger and not the 12w brick for charging the iPad.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
matt mocciola будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 34
