Repair guides and support for the second generation Honda Insight.
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
Это хороший вопрос?
Счет 0
1 Комментарий
Does the drivers side switch operate the window on the passenger side?
из
Добавить комментарий
1 ответ
Выбранное решение
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
William Salzwedel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 21
За всё время: 493
