Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Lightning connector melted!
Hello!
I was replacing touch screen on my iphone 7 when i was finished i tried to charge my phone after minute or two nothing was happening so i once more opened the phone and noticed some think in the connector has liquefied and then solidified. I don't know why is that. Can somebody please explain this ?
Update (05/25/2018)
Это хороший вопрос?
Оценка 0
5 Комментариев
can you post a photo of what you think has melted
из
Yes i just did.
из
sorry but i cant see which part you think is melted, is it to the left of the screw ?
из
did you disconnect the battery when you replaced the lcd
из
Surface around connector. I don't think that glowing think should be there. Yes i was careful about that.
из
Добавить комментарий
1 ответ
Выбранное решение
I can't see what you are referring to.
Do you mean this?
That's just epoxy to protect the passive components soldered onto the flex. Did you disconnect the battery first before removing your screen?
Go back through this guide and double check your work.
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
Thank you, yes i was thinking something is wrong when i saw this glue. I have clean inside the connector, and when you plug the phone inside a charging cable you can hear it vibrate, but the screen stays black thought.
из
Добавьте свой ответ
Timotej Arnuš будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 470
