Battery Calibration - Bootloop (after battery replacement)
Hey all. I apologize in advance- I know this topic has been asked and covered; however, I didn't see a solid answer and I think my situation is a bit different...
I installed iFixit's iPhone 6S Plus battery into my phone after many many months of descending battery life from the original. I installed this over the weekend and actually have it in my phone right now. I ended up having to bend/mangle the original battery as one of the adhesive strips broke/ripped before I could pull it out completely.
My PROBLEM: When I installed the battery, I was elated that I was even able to do that. I got the battery in and plugged it in to calibrate the battery. I know the instructions to calibrate the battery require uninterrupted charging up to 100%. Of course, the slightest movement from my dog happened and he bumped into the plug/cord, which disconnected/reconnected my phone immediately. I figured this messed up the battery calibration process?
Every time when my phone dies down to nothing and shuts down, it boots back up to the Apple logo, goes to black screen, crank wheel shows, and it goes into the boot loop of repeating this process. The phone usually drains down to about 2% before shutting off.
I've searched for answers on how to calibrate the battery properly and can't find a way to do it. The battery alone, uncalibrated, already lasts MUCH longer than my original battery; however, I'd love for it to be calibrated.
I've tried to let it drain, boot it up, let it drain, boot it up, etc. until it drains completely. I had one moment where the red battery icon appeared in the middle of the screen, as it should, and I left it plugged in after this to charge until full.
After letting it die down again to see if that worked - nothing. Still the boot loop.
Did I just mess the battery up by not properly calibrating. How can I calibrate this? Any help would be... helpful!
Это хороший вопрос?
