Left joystick doesn't work
Hi,
I replaced the left joystick my xbox360 wireless controller. Unfortunately one of the soldering came up. (up direction). I'd like to use a cable, but I don' know which is the point where connect it. Do you help me to solve this problem?
Thanks in advance
Zoli
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If you are stating that one of the solder pads broke when you attempted the repair, a photo of that area would help. You need to follow the traces from the broken pad to another are where you can attach a jumper wire. While not the most elegant of fixes, it should work. Please post the photo and I will try to guide you further.
Dan
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Zoli S буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 104
