Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1960 Questions Показать все
3G Digitizer works in 3GS!?
I have a 3gs with a cracked digitizer and i had a spare 3g one so i tryed it in it and it worked. I thought they werent compatible? Is it safe to use in it? Every part of the screen works no problems at all
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Комментарии:
Does the Compass App work correctly?
от
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
5 Ответов
Выбранное решение
Technically they are compatible but, can be a pain using some applications unless you are up to date with software.
The proper 3GS also has fingerprint-resistant oleophobic coating.
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
Strange, my 3g had totally different connection (digitiser) to that of my 3gs
от
how did you make it fit? i currently have the same problem
от
both digitizer are different . you cannot put a 3g on 3gs and 3gs one on 3g both are totally differ .
от
Наиболее полезный ответ
For anyone else I would NOT attempt this. You can easily damage the connector on the board and then you are screwed. That connector is not an easy fix, trust me I know...
Whether it works or not isnt the issue, it was not made for the phone. A new digitizer is only 10-20 dollars. Don't skimp on a $300 phone.
по рейтингу 2
im an apple specialist, iphone 3g and iphone 3gs have totally different digitzers, although they may seem the same and MAY even fit, they will slowly give problems and then your connectors will burn out
по рейтингу 2
They are absolutly not compatable connector wise.
[URL=http://imageshack.us/photo/my-images/841...][IMG]http://img841.imageshack.us/img841/873/d...[/IMG][/URL]
Tinner
по рейтингу 1
Hi I have had similar problem as you with 3GS, I bay standard 3gs digitizer for 3gs, but the connection was totally different from the digitizer placed on the phone. So now i have to wait delivery for the new 3g digitizer only and see what's will happened.
по рейтингу 0
Добавьте свой ответ
Jared будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 6
За всё время: 11,484
