The Epson L200 is an all-in-one color inkjet printer, copier, faxer, and scanner.
14вопросов Показать все
Didn't filled all Ink colors at the first time
Hello, I just bought a new Epson l310 printer.
in installation program i was asked if all of the ink tubes filled, i clicked yes, but actually i filled just the black color, the printer started to load the ink, it took 20 minutes and all was good with the black color, but when i filled the other colors, i couldn't do the same ink load like in the begining, and now i can't print with colors, what should i do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You may be able to do a factory reset on the printer, that mite bring up that menu choice again. In the settings there also may be a way to add the ink as well. Or you mite just have to do some print head cleanings that should start sucking the ink through.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Tal sharara будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 51
