Ts0S Memory Bank Proximity Sensor error
Hello
I have a unibody MBP Mid 2010 which was brick for a long time about the Graphic Card Issue and Kernel Panic and Shutdown (which is very common to this machine)
Recently I came across the info about faulty Capacitor and replaced it with a new one. After 4 years my machine works again ;)
Unfortunately the machine is very slow now although it has 8GB Ram and SSD. After a long research i understood that some sensors were not behaving as expected and sending out -127C as the reading which makes the CPU run at 800Mhz
The mentioned sensors are Th1H Th2H and Ts0S
I found Th1H and Th2H on the board and ordered new parts.
Yet again I could not find where Ts0S is on the logic board. What is this part and how does it work and how to replace it?
Any ideas?
Thank you
Это хороший вопрос?
