Plugged in but not charging?
Whenever I plug in my laptop, the indicator shows "Plugged in, but not charging".
1) I have to wiggle or find the perfect point to get my laptop to start charging.
2) Once getting into charging state, I can move, pull, or do whatever physically with the wire + plug and it will not leave charging state.
3) Unplugging the outlet and plugging back in brings back "Plugged in, but not charging" notification, and I have to do the whole wiggle thing to get it to charge again even though I did nothing physical to alter / change the position of the AC adapter wire + plug.
Laptop: Specs
Это хороший вопрос?
4 Комментариев
It also makes a weird hissing noise until you wiggle enough to start charging.
из Coby Hong
What makes the hissing noise? Charger or laptop? It looks like a 2-wire output plug so you could check the output with an voltmeter. Is it possible to try another charger?
из rokin154
laptop makes hissing noise. I don't have a voltmeter but I'm guessing charger works and voltage correct (Charges perfectly fine once I find the "sweet spot" from wiggling in... and after that I can tussle charger and bend the wire or jack however I please and not lose charge at all).
из Coby Hong
Hey so did you found the fix??
из Sanjeev Das
