What can be the cause of these intermittent screen displaying glitch?
Hi,
My MacBook Pro have intermittent screen displaying glitches, as you can see on this video I just took.
SYMPTOMS VIDEO:
http://site-web-reims.com/collab/MbProLa...
REPLACED PRODUCT :
I have already replaced the LVDS data cable :
MacBook Pro 15" Unibody LVDS Display Cable
GUIDE :
I have followed this DIY guide successfully :
MacBook Pro 15" Unibody Late 2008 and Early 2009 Display Data Cable Replacement
After the replacement, the glitches are still there :-/
What could be the cause of such an intermittent glitch symptom ?
Thank you very much ;)
Alexander
Это хороший вопрос?
7 Комментариев
Have you checked to see if it still happens if you connect it to an external monitor?
из Rus Weeks
Sorry for this missing information.
Yes : the display is correct on an external monitor. I suspect that the LCD display have internal lesion ?
из Alex Laforge
This will sound daft, but, try pressing different areas of the screen. I've had thing like this in the past, for some reason this fixed the problem
из Rus Weeks
Rus, I have pressed different areas of the screen, as you suggested me. It infortunately did not change anything : not worse, not better..
из Alex Laforge
Try pressing around the edges where the bars are. You may need to take the cover glass off to effect anything here.
из Dan
Показать 2 больше комментариев
