replaced all 6 sensors in my ford ranger edge but now wont go in rever
my ranger edge transmission was stuck in overdrive. I replaced all 6 sensor in transmission, Now it only has drive, No neuturel or reverse. What could be the problem?
Это хороший вопрос?
did you get the shift sensor aligned right?
из Jimfixer
yes pretty sure
из Paul Boner
You might have a blown fuse in your transmission computer. I had a 1991 Mitsubishi Mirage which was stuck in 2nd gear. The problem was a blown fuse in the transmission computer. When the fuse was replaced, the transmission problem disappeared. Perhaps there is a similar issue with your vehicle.
из MrJimPhelps
