The Western Digital My Passport Ultra is a USB 3.0 portable storage device with capacities from 500 GB up to 5 TB.
37вопросов Показать все
WD My Passport Ultra Not Detected
I have almost 1.5TB in this drive. Can still my WD My Passport Ultra be fixed? Or I just need the files within my hard drive.
- My WD My Passport Ultra was not showing in [My Computer].
- My WD My Passport Ultra cannot be initialized due to hardware error.
- My WD My Passport Ultra still not showing in [My Computer] using other USB Cord.
- My WD My Passport Ultra was shown in [My Computer] depending on how it was inserted to a USB Port but i could not open any folder/file within the drive.
Это хороший вопрос?
Оценка 2
2 Комментариев
i have problem with it
из
I need a program that can restore the wd passport
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
The drive being visible has multiple parts:
1) The USB interface must be working in order for the computer to recognize that there is a device at all.
2) The "driver" board on the disk must be somewhat working in order for the system to realize that the device is a disk and exists.
3) The actual spinning rust (called a disk) must be readable in order to store or retrieve files.
I think you may be having a problem with the USB interface and/or the "driver" board of the disc itself. Without seeing the device and poking around a bit, I can't be sure.
Dan
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Does it mean that i need to bring this on iFixIt so they could check it out?
из
Добавьте свой ответ
Serniel Barbosa будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,729
