Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
583вопросов Показать все
ink pad finished its service life
ink pad in epson xp-620 has finished its service life what can i do?
Это хороший вопрос?
Оценка 26
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Here’s a link that explains how you can temporarily continue to use the printer, but you really need to clean the waste ink pads and then reset the printer’s waste ink pad counters, to get it working again.
Here’s a link to a video that shows how to clean the waste ink pads in an Epson XP printer (hopefully it is the same for your particular XP model).
As suggested in the video after cleaning the waste ink pads you need to reset the counters.
Go online and search for Epson XP-620 reset waste ink counters to find results for suppliers of the reset software which you can purchase online
Был ли этот ответ полезен?
Оценка 17
4 Комментариев:
A printer's ink pad is at the end of its service life.
Please contact Epson Support.
из
I used a the WIC Reset Utility with the trial key - "trial" - from https://www.wic.support/ and it worked. This resets the waste ink counter to 90% and the printer came back to life.
из
Here is an excellent video how to replace the ink pads on the Epson XP-720 / XP-750: https://www.youtube.com/watch?v=yfQe5eDh...
из
wic reset is the best as above by david!!!!!
из
Добавьте свой ответ
k.hogshaw будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 60
За последние 7 дней: 343
За последние 30 дней: 1,625
За всё время: 74,697
