Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
32246 Questions Показать все
How can I detect if my iPhone is being tapped?
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
1 Ответ
Наиболее полезный ответ
A regular house phone has lots of space to slip in a microphone transmitter! Not really possible in a cellphone, no free space!
But! Your phone could be its own bug! Some Apps are able to monitor your microphone and send the data over the internet without you knowing. Now this is not really possible on an iOS based phone if you’ve only installed apps from the Apps store as Apple monitors such things, and we know Apple is very paranoid about security!
Some apps which do language translation might need to access to the internet to use the more powerful back end servers to figure out what you’ve said (they have said). In the case of Siri it to leverages a back end server for some of the work. So unless you’ve opened the channel it’s not possible for these apps to spy on you!
OK, how to prove it!
Simple, you’ll need to disable cellular services and only have your phone connect to a dedicated WiFi AP. Then have a network sniffer monitor the Ethernet traffic from this AP unit (dedicated network to your internet router) While you won’t be able to see the encrypted data stream directly, you will be able to see the numbers and size of the data alter as you talk to your phone (within a quiet room). If the data stream is consistent when its quiet and when you are talking you know your phone it not spying on you ;-}
It’s only when you yell out ‘Hey Siri’ or tell you phone to translate something to another language will you see additional data.
Был ли этот ответ полезен?
по рейтингу 2
Добавьте свой ответ
Nancy Ericsson будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 8
За всё время: 103
