Hearing a squeaking sound from the engine.
Everytime i release the clutch there' a squeaking sound for my chevy's engine. I tried changing the engine oil the day those weird sound started but it did not work. Are there other defaults related to the sound.?
Это хороший вопрос?
Оценка
0
Hi @sanzy ,
Are you sure that the sound is from the engine and not from the restore spring attached to the clutch pedal in the passenger compartment driver's position?
Try operating/releasing the clutch pedal with the engine switched off to check if the noise is still there and where it is coming from.
из jayeff
