The first-generation Honda Stream was introduced in July 2006.
6вопросов Показать все
Need extra fuse for towbar Honda Stream 1.7 LS 2002?
Dear all,
My mechanic (not official Honda dealer) installed a towbar on my Honda Stream 1.7 2002. He only was unfortunately not able to fix the power supply. He thinks I probably have to add an extra fuse. But it could be also a relais thing he says.
Ofcourse I can go the official Honda dealer but maybe I can fix it with help from you. Could anyone give me a good advice? Maybe experienced this issue himself?
Thank you very much!
Regards,
Nielsen
The Netherlands
Это хороший вопрос?
Оценка 0
1 Комментарий
Thanks for your answer!
This is the whole installation which is actually too difficult for me. I am not an engineer.
Was hoping for an answer like “put a fuse in row 3 socket 10 of the fuse board” . But this is maybe too simple
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Here’s a good video on how to do it:
https://www.youtube.com/watch?v=mb5hShis...
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
из
Well you are going to have to add the wiring for the lights and brakes for what you are towing. Adding a fuse just doesn't cut it. This is not as difficult as you might think, just take it one step at a time. You know, the same way you do heart surgery.
из
Добавьте свой ответ
Nielsen Vermij будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 256
