Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Это хороший вопрос?
Счет 4
2 Комментариев
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
из
Grateful it worked
из
Добавить комментарий
4 Ответов
Выбранное решение
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Был ли этот ответ полезен?
Счет 10
6 Комментариев:
This worked for me, thanks.
из
purrrrfect solution , thank you
из
Worked for me too thanks!!
из
This worked thanks alot. ?
из
Worked great for me. Thanks!
из
Показать ещё 1 комментарий
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
Счет 1
1 Комментарий:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
из
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
Счет 1
2 Комментариев:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
из
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
из
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Счет 1
Добавьте свой ответ
Robin Kamps буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 48
За всё время: 23,577
