Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
All lights are blinking, and tryied to reset with epson adjustment
I have an Epson TX105. It was my fault, paper got stuck (that wasn't my fault) and I removed it (that was my fault)
now all the lights are blinking, and I don't know what else to try.
Thinks I tried:
Take out power supply
using epson adjustment tried almost every test and all failed to fix it
Это хороший вопрос?
Оценка 47
13 Комментариев
Clean the printer from inside and put some silicone oil on the bar on which head moves
из
is there anybody can help my problem… I have Epson L405 is now PAPER JAM , i’m trying to follow the instruction but still have a problem still blinking the Paper Jam indicator.
из
is there anybody can help my problem… I have Epson M105 is now PAPER JAM , i’m trying to follow the instruction but still have a problem still blinking the Paper Jam indicator.
из
Epson L805 me red light bling kar raha h,
Colour khatam ho gaya tha fir colour dala hu fir bhi print nahi ho pa raha h please help me..
из
Hi I have Epson L380 Printer is showing End of Life Inkpad...
из
Показать 8 больше комментариев
Добавить комментарий
Ответов (17)
Выбранное решение
All lights flashing is called a "Fatal Error" This is PER EPSON. I use to see this weekly from people that had a paper jam. When you un-jam the paper, I'm guessing you pulled it out the way it went in. What happens when you do this, is you actually pull the paper sensor out of it's cradle. Therefore it sees that the sensor is not functioning properly, giving you a fatal error. If I remember correctly it is quite a pain to get the sensor back where it belongs. IF you are mechanical and want to give it a try, just be careful and remember where everything goes. Write it down or something.
Look into the slot where you feed the paper in. you may be able to see the sensor with a flashlight. It's impossible for me to walk you through this, but if you want to try, now you know what to look for.
If this was an inexpensive printer. ($50-$60) Personally, I would get another printer instead of trying to fix it. From a service point of view, the labor to fix this if you brought it into my shop would be more than a new printer. Providing it was a cheaper model.
Был ли этот ответ полезен?
Оценка 37
12 Комментариев:
I had a fatal error too but it was not related to the paper in my case. All I had to do with mine was change one of the cartridges, even though it still had some ink in it. Wasn't using the original cartridges and I'm still not using the original cartridges, but at least now it's working.
из
My Epson L210 blinking red light and say for ink ped services
из
my epson l220 2 red lights blinking, green one blinking also. I cant print, this happened when my printer ran out of paper. and now when i put it on it makes a noise and the lights starts to blink. i have tried a lot of things but nothing helps
из
my epson l130 red light blinking grenn on also .
из
How to rest Inkpad error is showing End of life rest inkpad
из
Показать 7 больше комментариев
sir.....i am problem is two lights on this printer ink and pad lights on off continuesaly
this solved my question
Оценка 14
1 Комментарий:
Epson printer L3100 ink lights are blinking
из
my problem is epson l210 model its 2 light bling king alternet
Оценка 7
1 Комментарий:
epson l380 page and ink lagthe show
из
i have epson l380. both red light blinking. what should i do ?
Оценка 4
2 Комментариев:
I have Epson L130 when i switch on the printer roller moving very fastly like fan speed and all three lights are blinking
из
I have Epson l3111 and the light keeps on blinking every time I do 5-10 photocopies. I turn off the printer wait for some minutes and turn on the printer and the problems varnishes. My problem is the lights(all) keep on coming now and again. I performed an inkpad reset but the problem is still there. Any solution for this
из
You can try with this guide: How to Hack Epson L200's Waste Ink Pad
Оценка 3
1 Комментарий:
My name is Ben. I bought an Epsom aculaser m2400dn from jumia Nigeria and I received it on Tuesday 24/7/2018. I installed it but it was given me General Error E004 and the lights were blinking. Please guide me on how to fix the problem.
из
sensor is not work. please replace the sensor.
Оценка 2
i have epson l805 and all lights are blinking and not taking paper in what to do?
Оценка 2
Workforce K101 - Deep paper jam issue caused ALL BLINKING LIGHTS on EPSON WORKFORCE K101. Checked for paper on the print path... SOLVED ISSUE.
Оценка 2
1 Комментарий:
Hi I have the epson xp-2150 I have just changed my ink for the second time and my paper jam and my ink light are both on not flashing what can I do to fix them I can't print at all thanks
из
i have epson lx310 and all lights are blinking what to do?
Оценка 1
My one L355 got the "fatal error" after print head replacement :/ I still can "print" though, but only blank paper is coming out. Printer behaves as if it was printing but just all lights are blinking and no ink on paper.
Оценка 0
3 Комментариев:
My printer is Epison Artisan 1450 Series it has reached a point where it prints slowly as if it is thinking whether to print or not, Currently, it has stopped printing. it is leaking a blackish oil like and at the same time it is blinking. when i restart the printer it displays a massage "Printer Busy" yet no printing job in the qeue. please help am stuck
из
me pasa lo mismo
из
can you solved it?
из
i have an epson L110 and the ink pad and paper are blinking including the power what to do?
Оценка 0
lights blinking problems are
1. waste ink pad full and back roller spring problem (remove spring inside roller)
2. main roller jams (rubber, spring, roller cracks when rolling check it)
3. left side of the printer roller sensor rubber clean it
4. carriage jam remove the header see back side replace sensor (yellow color jammer)
5. remove dust inside and paste Greece to rollers
6.use cyan, magenta, yellow (original ink) and black(duplicate)
Оценка 0
1 Комментарий:
hello, can you help me troubleshoot/fix my 1500w / 1430 all of the lights are blinking , I can pay you to help
из
i have my problem with epson l565 printer. as i turn it on the blue power light is flashing but no power. sometimes it turn on but it takes several minutes or sometimes an hour to do so. i need help.
Оценка 0
Hi
I have an epson l3060
When I was doing Head Clean, the printer's all lights blinked
I turned the printer off and turned on and the head moved to end and I heard a sound from head's belt and the lights blinked again
the printer had not any paper jam and i test the loading a paper and it was no problem
do somebody knows what happened is? Please help me
Оценка 0
The two white plastic sensors should be under the paper.... mine were not so, when I pushed on the power button, I held them gently under the paper and the lights stopped flashing
Оценка 0
I have a (white) EPSON Expression Home XP-247. After inserting my ink cartridges and instructing it to print a page via CUPS, all of its light flashed simultaneously. Consequently, I reinitialized the printer and reseated the ink cartridges. This remediated the problem.
Оценка 0
My menu light does not come on and the menu light tells you how to print. How to you fix the problem?
Оценка 0
1 Комментарий:
I believe you've posted this as an answer, whereas you should have posted this as a question.
из
Добавьте свой ответ
Alvaro будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 27
За последние 7 дней: 179
За последние 30 дней: 855
За всё время: 284,173
