The Nutri Ninja Ninja Blender Duo BL641 is a 72 oz. black blender that comes with 1 Jumbo Multi-Serve 32 oz. container, 1 Regular 24 oz. Nutri Ninja Cup with Sip & Seal Lids for on the go, and a 75 Recipe Cookbook. Its strong blades can crush ice and pulverize fruits, vegetables, and seeds with different buttons for different settings.
Where can I buy to replace the motherboards?
Where can i buy to replace the motherboards for Nutri Ninja Ninja Blender Duo BL641
Это хороший вопрос?
Счет 4
1 Комментарий:
Goodnight.
How can I buy a card from this blender?
из
Добавить комментарий
2 Ответов
I did a cursory internet search and not much turned up. A full replacement main board may not be easy to come by. That leaves you with a handful of options:
  1. Take a roll of the dice and see if you can find a used one on eBay (I wouldn’t recommend this unless you have good relations with the seller)
  2. Contact Shark/Ninja and ask if they have the parts and get a quote/see if they will sell or give you one
  3. See if your ninja is still under warranty and file a claim
  4. Since the main board is relatively simple, determine which component has gone bad and replace it (i.e. resistors, capacitors, etc.)
I don’t recommend performing option number 4 unless you are very comfortable with electronics.
Best of luck! And remember to be safe when working with electricity and electric components.
Here is a guide for using a multi meter to test components on the PCB
Here is a guide for testing different PCB components.
Был ли этот ответ полезен?
Счет 0
Where can I buy a replacement motherboard for a Nutri Ninja Pro BL494 30S
Счет 0
Добавьте свой ответ
Arden буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 1,395
