Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64вопросов Показать все
How can I make a dvd copy of movies?
I've recorded some movies in 25 fps but when I burned it on a dvd the speed of playing dvd wasn't correct and it has been shown more slow than normal
How can I fix it ?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi.
If you’re trying to watch PAL frame rate video on a NTSC type display device then it will be too slow. (I’m assuming that you had PAL video mode selected in the camera)
Try using software - example only to convert the frame rate from 25 to 29.97 and see if that works.
There is other software available to do this. Just search for video converter software.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
akavoli будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 54
