Игровая приставка от Sony Computer Entertainment, анонсированная 20 февраля 2013 года и выпущенная 15 ноября 2013.
1008 Questions Показать все
Disc Drive is not auto inserting discs
So I recently picked up a PS4 with a faulty disc drive to see if i could fix it, and the problem is I can't find what's causing the problem with the disc drive. Essentially, it will not pull in discs, or eject them. Using the manual eject screw, I can move the disc in or out, and if I put the disc in, then turn the PS4 on, it will read the disc just fine. The only problem seems to be the fact that it will not pull the disc in, and when I hit the eject button, it makes a beep, but won't make any sounds internally to indicate that it is attempting to eject the disc. I've taken it apart, and all the rollers and gears seem to be in the right place. It doesn't make any noises whenever I try to push it in to get it to auto insert, which I think means that it could be the sensor not noticing a disc, or maybe even the motor not being capable of pulling the disc in, however I don't think the latter is the answer, as I can't hear it even making an attempt to move things inside the PS4. I'd like to try to narrow down what part it might be before I try to buy and insert replacement pieces, just so I don't have to buy the incorrect piece since I don't know what's wrong. Any help would be greatly appreciated
Это хороший вопрос?
по рейтингу 0
Комментарии:
I'm not sure exactly what type of drive this is, but you might get a hint or two from oyr Restart Wiki at https://wiki.restarters.net/CD_and_DVD_p...
by
FWIW, my PS4 was doing the same thing for a couple of weeks. I eventually just blew a bunch of compressed air into the drive slot and the problem went away. I chalked it up to a dirty sensor and continued playing.
by
Добавить комментарий
Android Fix Kits
A new screen or battery is one kit away.
Купить сейчас
Android Fix Kits
Купить сейчас
1 ответ
Наиболее полезный ответ
If you remove the drive from the case and turn it upside down, you should see 2 black "arms" that form a "U". These have posts that are hit by the DVD when it enters the drive. With the ends of the arms facing away from you, look at the lower right arm extension. You should see 2 square parts that may be gold in color. These are the micro-switched that trigger the load/unload process. I would verify that these are working properly. With a continuity tester, push in each one to see if it works. I suspect that one of these has failed.
Report back here with the results.
Dan
Был ли этот ответ полезен?
по рейтингу 2
Комментарии:
I am having the same problem but my PS4 won't let me insert a disc at all. Just took it to a place and all they did was replace the disc drive. And still won't take a disc
by
Добавьте свой ответ
Chloe Wallwork будет вечно благодарен.
Просмотр статистики:
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 255
За всё время: 1,529
