No heat and gas smell in dryer when set to low heat
When set to high heat dryer appears to work fine. On low heat setting there is no heat and a strong odor of gas in dryer when you open door after a minute
Suggestions
Это хороший вопрос?
Suggestions
Это хороший вопрос?
If you are having trouble with a funny smell inside your dryer or on your clothes, consider this...have you painted or varnished anything inside the home recently? Your gas dryer uses a lot of air, not just the air that blows out the vent but the air used to burn the gas ( natural or propane ) as well, anything like paint fumes or varnish fumes in the air will be picked up in the air used by the burner flame and burnt....this is often described by customers as - burnt fabric softener smell ..... - burnt soap smell .... - burnt medicine smell. Open your windows, air out the basement/home as good as possible, most customers tell me this will go away after a week or so once everything is dried and all the fumes are gone. Remember, if you smell gas....turn off the gas valve to the dryer and call for service!!
A tip from ( A Fire Marshal ) - This is sometimes caused by the filter not being completely clean. By this I am referring to the clogging of the screen from the use of fabric softener sheets. The chemicals in these sheets will, over a period of time, impair the air flow through the screen and cause the "gas odor" to become prominent – not to mention the temperature to rise within the dryer. I clean my filter with soapy water and a tooth brush about every other month and it keeps this from occurring.
Был ли этот ответ полезен?
Not a funny smell. Gas smell, No heat with smell when on low heat setting
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,425
1 Комментарий
Having same issue just on low heat.
из Theodore Johnson
