Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Touch screen doesn't work
Hi guys
I have problem with my iPhone 7 touch screen !
It doesn't Response at all and it seems display has a problem too because it's filled with lots of small squares in background But homepage can be seen good !
I tried hard reset but it didn't fix . After I powered up my iPhone in Apple's logo there was a shadow of battery Percentage !
Did anyone face this problem ever?
Will restore help?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
This sounds like a hardware problem for sure. So no, its not likely that a restore will do anything for your device.
If you have not dropped or damaged the device at all apple may replace it for free.
But it sounds as if the LCD screen has gone bad and needs to be replaced.
I'd check with apple first, and if they don't do it for free or cheap find someone reputable that will. Or do it yourself with an iFixit Guide!
iPhone 7 Screen Replacement
Hope that helps!
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Alireza sadeghi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 41
