Replacing broken screen with a titanium screen.
Hi there!
Does anybody know if I could replace the lcd screen of a 15" G4 Powerbook 1.67 GHz with one out of a 15" titanium powerbook?
Many thanks
Sascha
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
Scoot Head, if you check these two links you'll find a reference for the Titanium LCD: AU Optics Corporation - PN B152W01 (works in all Titanium models). Looking at the other link, the same B152W01 is advertised for the PowerBook aluminum.
http://home.comcast.net/~macdan/tibook_d...
http://www.powerbookmedic.com/Aluminum-P...
I would be not surprised that you could swap the LCDs (of the same resolution) between the two series minus the 1.67 high resolution PB G4. I often swapped iBook G4 LCDs with iBook G3 ones
.To Sascha: if you want to know your LCD model:
- open Terminal application
- paste this line:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
-hit the RETURN key
Once you have the information, search on Google to find if you can get a match with a model of Aluminum PB LCD. Good luck !!
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Hi lemeris
Following your instructions, I get the same result on both machines: LTN152W3
Does that mean they are definitely compatible?
Thanks
Sascha
из
The two panels have the same model number ? So yes it should be compatible.
из
Наиболее полезный ответ
They are different parts so no, you would not be able to use the Titanium LCD for the Aluminum PowerBook.
Оценка 2
1 Комментарий:
Thought so, thanks for your answer!
из
Why is it I feel like a Pakled when I go to sites like this?
Оценка 0
Добавьте свой ответ
redfordbertl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,466
