I spilled a sip of liquid (flat white) on my MacBook Pro TB 2017?
I accidently spill some liquid (flat white) on my Macbook pro 2017 Touchbar, luckily I had a keyboard cover which protected the keyboard, but some fell on the speakers grill (on the right side) I cleaned it right away with my fingers and napkins then put a napkin on the speakers grills, closed the lid and put the macbook upside down so it can be drained somehow with gravity, I think the napkin was very very slightly wet that it can barely be noticed after I removed it, then put a new napkin again and left it upside down till I reached home 2-3 hours later, I removed the napkin it was dry and I used a vaccum cleaner 5-10 times on the speakers and the keyboard close to it ,The macbook is working normaly till now and the speakers also are working as usual I guess, I’m really worried that there might be some damage that I can encounter later, my question is , How long should I wait to be relieved that nothing would happen ?
And also if there is something else I should do ?
Sorry for the long post.
Thank you in advance.
Это хороший вопрос?
3 Комментариев
To be clear this is white ceiling/wall paint.
How much did you spill? Is this a thick paint or very runny? As it turns out the speakers can be replaced and you can gain access to the inside surface of the grill
из Dan
no no flat white is an espresso drink, it’s like a cappuccino, I’m not sure exactly how much but I hit the cup and it moved a bit it didn’t fall or anything I think I spilled about 3 cm3 or something, I tried the speakers volume it seems normal to me, everything seems so normal but I’m panicking that I might encounter some damage later, I tried vaccum cleaning it a few times and everything is fine till now
из Peter Labib
So you use a torch Vs a flashlight ;-}
из Dan
