Martin,Is this a new error? did you change any of the setttings? Has anything preceded this problem? You can give this a try. In the settings under network, disable Media Server and disable Auto Sign-in as well and see if that makes a difference. If that does not work at all for you, it could be that the IP address on your PS3 is wrong. That way your PS3 cannot connect via router to the internet, no matter what DNS you have configured. Set your PS3 to obtain the IP address and DNS server addresses automatically via DHCP from the router. You do not need to configure the OpenDNS servers explicitly on any connected devices, whether it be a computer, or PS3, or Wii, or iPhone, etc. I believe that there might also be issues that originate from the wireless controller, but I have not researched that possibility in depth.
There is plenty of info about this happening and I am sure it is not a hardware issue but a software setup problem. Check here and here as well Good Luck and I hope this works for you.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
4
I AM GETTING THIS ( error code 8002A537 ) EVERY TIME I LOG IN TO PS3 AND my ps3 keeps freezing up and all so i keep losing my sound of game play but not the mic sound ?
из craig371
@craig371 same $@$* here!
из Fikito
My ps4 every time i turn it off it makes me log back into my account when I turn it on and when I go on my games it makes me do all the beginning stuff again.
из Lucy Sklarski
My ps3 says an error has occurred. Signed out of playstation network (error 80710016) or something like that then I go to test wifi and it doesn't even show anything but connection to internet and it address found it doesn't say psn found and all the other stuff please help I just bought a shark card in gta5 for 50 bucks
из kalebwachal22
Have you found a solution to your problem??I have the same too!!
из Skillboard
Показать 3 больше комментариев
