Camera Won't Turn on After Many Hours of Charging
Hey all,
I got this camera as a gift a few years ago, but never had much use for it, so I kept it stored safely in its case. I recently picked it up again, and have had it charging while plugged into my computer for about 12 hours now, but it still won't turn on. There's been no damage to it whatsoever. It does flash green and beep when plugged in, so one would assume it is charging...
Can anyone help?
Это хороший вопрос?
2 Комментариев
Hi Bev Cummings , had you tried taking the battery out from the device and use an external charger to charge the battery?
do you have a multimeter?
after some time of charge, use a multimeter to measure the battery, to ensure it is holding on the charge, which i suppose is around 3.7V
из Augustine
Unfortunately I don't have a charger that will fit the battery, or a multimeter. Should I just assume I need a new battery?
из Bev Cummings
