Can Pro4's Samsung screen being replaced by LG's?
Unfortunately, I also suffered LCD screen failure of Surface Pro4 like the most of people. I don’t know how to called this issue but I believe you know.
Now I’ve purchased a brand new LCD pannel from Chinese Taobao to replace its original pannel Samsung LTY123YL01-005 (AIDA64 shows -001 though). I’ve learned from forums and websites that Samsung’s screen for Pro4 has flaws and Microsoft switch it to Pro5’s LG LP123WQ1 at the last batch. So I also purchased LG’s.
The seller told me that connector cable also needs to be replaced because Samsung’s is not compatible. After a few days I received my new scrren and connector. But after installation I can see nothing showing on the new screen, it was totally black including the backlight.
I’m confused. Is that old Surface Pro4 model incompatible with new LG screen? The new connector can connect scrren to mainboard correctly and OS boots normally but I can’t get any image.
Another thing is I discovered this new connector’s solder joint having some problems. AIDA64 cannot find new pannel’s name(viewed from Microsoft RD) and I doubt that the seller sending me a bad connector.
Now I’ve bought a new connector from another seller and it’s on the way. But I still holding the question. Can Surface Pro4’s Samsung screen being replaced by LG’s directly? Did anybody also completed the same replacement?
Это хороший вопрос?
2 Комментариев
I have just removed an LG screen from the Pro 4.
So if I change the LCD flex for the Samsung screen will it work ok?
Or am I best to use the LG screen for the Pro 5?
The Pro 5 screen is more expensive than the Samsung Pro 4 screen.
из JO HILL
Hey bro, how will I know if it is Samsung or LG is needed for the screen? where to look for identification? I already have 2 screens but it doesnt work. I might have different flex or screen place. thank you.
из Dhoy Regalado
